User error bent a fin
  • dttheel
    • Jan 2014
    • 193
    • Crozet, VA
    • 2023 GS 22 2013 SAN 210 TE - sold
    I had the boat too far up in slip and when raising up the boat, the lift bent one of the three fins attached to the hull. It looks like a relatively easy fix...order new fin from NautiqueParts.com, unscrew the bent one and attach the new one. Am I missing something?
    DTT
    2013 SANTE 210
  • xlair
    • 694
    • Wisconsin
    No you got it for the most part. Be sure to use some new sealant when putting the fin back on.
    2001 Pro Air Nautique
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      NP will hook you up with the right sealant. Impact driver was handy getting the tight Phillips screws loose.
      2005 SV-211
      • dttheel
        • Jan 2014
        • 193
        • Crozet, VA
        Thanks for the advice, guys. The "job" is done. The screws came out pretty easily, but getting the sealant to let go was by far the hardest part. Ready to go back into the water tomorrow.
        DTT
        2013 SANTE 210
