2000 super air gt40 wont idle in gear
  • joewoody
    • Mar 2014
    • 13
    • oak ridge n.c
    • 2000 super air
    i have replaced my motor this past weekend. timed it new manifolds and all. I put the boat in the water today and you put it in gear and it will die. with idle set to 600-700 with the little grey plug out. when I put the plug back in it idles up to about 1000 and stays when you put it in gear it drops to 500 and then dies. also the idle is a little off it bounces around a bit it goes from 750 to 1000 and then back to 1000 and stays for a few seconds and then back to bouncing around. it runs great above 1000 but under that in gear will not run please help. o bye the way I hate electronics makes everything more difficult
  • Brian Sullivan
    • May 2014
    • 28
    • Mesa az
    Have you found a fix? I have started to have the same problem. Mine doesn't die but does bounce around at idle.
    • Chexi
      • Feb 2025
      • 2119
      • Austin
      • 2000 SAN
      Probably a distributor-timing issue.
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • kend
        • Oct 2013
        • 193
        • DFW, Texas
        • current 2001 Air Nautique previous 1988 Sanger DX
        x 2 on it being timing. Makes a motor where it can't handle any load if timing is off/distrib not advancing
        Ken
        2001 DD Air GT40
