Muffler rattle not against the hull
  • jhersey29
    • Nov 2013
    • 330
    • Colorado
    Can anyone help on this noise? The muffler is not rubbing on the hull. I took it out last weekend added dense rubber to test with and gave it a good shake but didn't here anything.
    The video should found here if this works from my phone. https://onedrive.live.com/redir?resi...nt=folder,.mp4
  • NigelC
    • 161
    • UK
    • 2010 Ski Nautique 200 Open Bow Team Edition
    Most likely a loose baffle inside the hull hugger. Looking at the video, it seems as though this unit may have been previously been repaired as there looks to be a repair band around the middle, halfway between the inlets and the outlet.
    I had an issue following a backfire on a '99 Ski Nautique in 2006. The muffler split clean in half. It required internal repairs to the baffle structure before the outer casing was re-glassed. Is your engine in the video running on trailer or afloat??
    2010 Ski Nautique 200 Team Edition Open Bow, Radar Strada
    Dealer: http://www.midlandsnautique.co.uk
    • jhersey29
      • Nov 2013
      • 330
      • Colorado
      It's floating next to the dock off the trailer.
      • jhersey29
        • Nov 2013
        • 330
        • Colorado
        Update found the rattle
        https://onedrive.live.com/redir?resi...int=video,.mp4
        • jhersey29
          • Nov 2013
          • 330
          • Colorado
          More video's
          https://onedrive.live.com/redir?resi...hint=folder%2c
          And a reference thread for where some of these idea's came from. http://www.correctcraftfan.com/forum...le=hull-hugger
          • jhersey29
            • Nov 2013
            • 330
            • Colorado
            Sunday morning. A few more steps an some video's. Good thing it is snowing in Denver on May 11th. I might need tomorrow to finish up. Cold garage is slowing down the setup time. And if you use the heat gun don't use the engine cover as a table. I noticed the muffler getting warm on the bottom and almost burnt the vinyl on the cover.
            • NigelC
              • 161
              • UK
              Pleased that you have found the problem. Looks like you are doing a good job with the repair. Quite time consuming but it will be worth it in the end as replacement hull huggers are not cheap.
              • jhersey29
                • Nov 2013
                • 330
                • Colorado
                That was a fun project. This link will take you to all of the videos and the final 3. http://1drv.ms/1nGGofy
                Hope someone finds this useful one day.
