Front light
  • ksoskeeter
    • Apr 2014
    • 4
    • central tx
    • 2003 210 team super air
    Front light
    Hey have question how do you turn the front light on on a 2003 210team super air hit button for light tower light comes on but can't get front to turn on
  • core-rider
    • 1350
    • Huntsville, AL
    • 2003 Black SANTE
    Do you mean the red/green navigation light? Pressing the navigation light button so the light on the button is solid will turn the red/green light and white 360 light on. Holding the same button down will only turn on the white 360 light. The light I the button will then be blinking. With either scenario pressing the button again will turn the navigation lights off and the light on the button off.
    If this is what you are doing then the bulb may be burned out needing replacement for the red/green light.
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • ksoskeeter
      • Apr 2014
      • 4
      • central tx
      thanks must be a wiring issue have no power at the light thought that might be the correct button
      • lucky7t
        • Mar 2011
        • 1306
        • Oklahoma
        • 2015 SANTE
        If I'm correct and I think what core-rider is saying is hold the button down
        Current Correct Craft Boat
        Correct Craft Boats Owned
        • core-rider
          • 1350
          • Huntsville, AL
          • 2003 Black SANTE
          That is only if you want just the white 360 light on... The light on the button will be flashing. For both the red/green and white lights to come on the button just needs to be pressed and let go... Making the light on the button steady on.
          Jason
