Integrated battery charger
  • toomuchuv
    • Mar 2013
    • 190
    • Canada
    • 2014 SAN 230
    Hey folks,
    Just wondering if anyone has added one to their ride and if so, did you add a through-hull plug somewhere? I bought one for my boat and can't decide if I should go through the hull or just leave cord accessible.....
    "I'm on a boat........"
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    just leave the cord accessible.... run it back to one of the rear tunk compartments and zip tie it right under one of the lips, as far back to the transom as it'll reach with a little 2-3" slack so its easy to grab and plug in.. so you can from the swim platform... pop open the trunk, plug it in with your extension cord, and shut the trunk.
    I would not waste the time or money cutting a 1"+ hole in my fiberglass for that. Its just too easy and quick with this^^ setup. Good luck.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • toomuchuv
      • Mar 2013
      • 190
      • Canada
      • 2014 SAN 230
      how do they do it in the new G series? Same??? ^^^^^^
      • TxHr
        • May 2012
        • 100
        • San Antonio, TX
        • 2007 Nautique 226 TE
        +1. My charger power cord is tucked-up under the lip of the storage compartment behind cooler port side. I'm not a fan of drilling holes.
        • MLA
          • Dec 2009
          • 1312
          • Lake Wylie NC Area
          Not a CC, but the same concept. Outlet is located in the rear locker. Your extension cord can be snaked out of the locker, so the hatch closes and down the side so to not interfere with the cover.
          • axeman
            • Apr 2012
            • 387
            • Dallas, TX
            • 2016 Super Air Nautique 230
            +1 against through hull. Just pop open rear trunk and plug it in.
            • toomuchuv
              • Mar 2013
              • 190
              • Canada
              • 2014 SAN 230
              Thx guys..... MLA that is the same connector I bought. Going to do exactly that!!!!
              This forum is awesome!
              • obd666
                • Feb 2010
                • 793
                • Bostian Heights, NC
                • 03 SANTE
                which charger did you go with toomuch? i am planning to do the same thing here shortly, and was looking at the prosport 8 dual bank to manage both batteries. is that what you're going for?
                2003 SANTE - "OG 210"
                • toomuchuv
                  • Mar 2013
                  • 190
                  • Canada
                  • 2014 SAN 230
                  [QUOTE=obd666;225787]which charger did you go with toomuch? i am planning to do the same thing here shortly, and was looking at the prosport 8 dual bank to manage both batteries. is that what you're going for?[/QUOTE
                  Canadian Tire has the NOCO Genius 2 bank on sale this week. Completely waterproof and shock resistant. I'm running 3 deep cycles in parallel for my stereo and a single optima for starting. Perfect unit for this setup and I'll be all-in for less than a hundred bucks!
                  • obd666
                    • Feb 2010
                    • 793
                    • 03 SANTE
                    nice
                    • Dave Rittiman
                      • Apr 2013
                      • 209
                      • Nor Cal
                      • 2009 Nautique 230 Sold 2016 Supra SE450
                      [QUOTE=toomuchuv;225791]
                      I am running the same charger works great I just have the cord under seat when I get home I just plug it in. My batteries are Northstar deep cycles I can run my stereo for hours. The stock alternator s can't keep up so if you have your batteries charged via the genius you are good for the whole day. Typically you can get about 2+ hours per battery, so running 3 in series it should last you 6 - 10 hours.
