Folks,
Looking for some help with perfect pass wakeboard pro. Had the boat out for the first time 2 nights ago and had a problem with the throttle going to the floor. When I got to looking at it the "knob" and cable on the PP servo was way loose. I turned it til no slack was in the cable and then the boat and throttle worked fine.
Took the boat out for a run and everything was running great. Looked at the PP gauge and it lit up green but there was no data. I looked at the manual for the PP and it says to check voltage at the servo motor. I checked tonight and it was fine. 12+ volts.
It also said to test to loosen up the cable with the boat off and then when you turn the boat on it will "auto-tighten". This is not happening. I am able to turn the know when the boat is on which I should not be able to do.
Is there a way to check the servo motor to see if it is back with a multi-meter?
The next thing that PP says to check in the manual is the master module.
Has anyone else had any problems like this?
thanks for the help in advance.
