2nd battery gt40 2001 SSN.
  • brettmcox
    • Jan 2007
    • 284
    I am in the process if added a 2nd battery to my boat. However, I not sure on the best way to add the battery to the system to safe guard that I will not being stranded on the lake with a dead battery.
    One amp running tower speakers and amp running sub, along with standard Head Unit. Not out on the lake running lights at night currently.
    I am thinking about leaving the stock wiring setup as is with amp running off stock battery and all the stock wiring. Along with the power wire running to the starter as it currently setup.
    The second battery will be wired only to the starter with a FORD style solenoid between the battery and the start positive side, and running a wire from the Yellow wire on the starter to the extra solenoid. The solenoid should only send power when the Start Button is pushed.
    The 2nd battery will be changed by a combiner 100 from yandina.com.
    Should this work?
    The other idea is to ONLY run the AMP off the 2nd battery but I not sure if there is an issue of running the Head unit off the Standard wire set up and the Amp running off the second battery. I am guessing I should remove the Remote wire from the headunit and adding a switched wire from 2nd battery. But if I go that far, I might remove the Power and ground from the headunit and run them directly to the 2nd battery (fused) as well.
    If I go this way, there is a chance that the radio could drain the stock battery and the amp could drain my 2nd battery.
    2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    You would have to run your deck/head unit for days to drain a battery to the point it wouldn't start a motor. I have a Blue Sea 1-2-off switch running two 65 series odyssey batteries. Battery 1 is the factory boat system with deck while the 2nd is amps only. I am running a wet sounds Syn 4 to my tower, a second Syn 4 to my interior speakers, and a Syn 1 to my sub and haven't had any issues running that way. I will sit at times for over an hour before I crank the motor and have never been stranded. I have a 2001 super with the upgraded 100amp alternator.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
