fish wire from engine to dash on air/sport
  • kend
    • Oct 2013
    • 193
    • DFW, Texas
    • current 2001 Air Nautique previous 1988 Sanger DX
    Hi,
    Does anyone know the easiest route to fish a transponder cable from near the front of the engine to the panel below the throttle? Installing a depth sounder on a '01 Air Nautique.
    bonus question: Does the toe kick panel where the fuse block is come out, or is it molded?
    Thanks much,
    Ken
    Ken
    2001 DD Air GT40
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    I have a Ski which I believe has the same helm as the DD Air. The kick panel is held in place with 4 long screws. If you have Perfect pass there may be a wire for the jump switch already between the engine and dash. I would pull a rope such as starter rope for a lawnmower or wire through with the PP wire then pull what you need from the engine with another string or wire. Then pull the PP wire back. I hope this makes sense. The PP wire will be grey and have 4 colored wires in it. It should be grouped and tied just in front of the engine on the drivers side.
    Nautiqueless in San Diego
    • kend
      • Oct 2013
      • 193
      • DFW, Texas
      Great, it has an added perfect pass and the speedo is right next to where I'm putting the transponder but I didn't think of that. Thanks a lot, that should make it easy.
      Ken
      2001 DD Air GT40
