Can someone video the water output of your hotwater shower system?
  • SilentSeven
    • Feb 2014
    • 1868
    • Bellevue WA
    • 2004 Nautique 206
    Water comes out of mine like a limp willy. Something is fubar....I think. Like to see what other pumps are producing. Did an archvie search and found nothing related to R&R the pumps. Can I really be the first person?
    Thanks!
    Bellevue WA
  • Nordicron
    • Sep 2009
    • 557
    • Madison, WI
    What kinda pump did you put on? Was it the heater craft kit?
    • SilentSeven
      • Feb 2014
      • 1868
      • Bellevue WA
      • 2004 Nautique 206
      Factory setup on a 97 196. Boat is new to me...sorting out stuff.
      Bellevue WA
      • Nordicron
        • Sep 2009
        • 557
        • Madison, WI
        Should come out pretty decent so long as all connections are tight. can u take the spray head off? My guess is it might be clogged with lake junk and mineral build up.
        • SilentSeven
          • Feb 2014
          • 1868
          • Bellevue WA
          • 2004 Nautique 206
          ...that's sort of what I figured. I likely just disassemble the whole thing and try to blow it out.
          I have yet to see anything on the pump itself...if there's an impeller or something that can be replaced. Any ideas?
          Bellevue WA
          • vision
            • 518
            • NC
            • 2013 G23
            Idling the flow is usually very poor. Rev to 2000 rpms and the flow should be good if not clogged.
            • SilentSeven
              • Feb 2014
              • 1868
              • Bellevue WA
              • 2004 Nautique 206
              K. Tried this, no love. I have pressure (when I shut off, turn on i get a good burst) but no volume. Pump doesn't sound real good.
              Bellevue WA
              • SilentSeven
                • Feb 2014
                • 1868
                • Bellevue WA
                • 2004 Nautique 206
                Looks ok here...not clogging at the head...
                Bellevue WA
                • Nordicron
                  • Sep 2009
                  • 557
                  • Madison, WI
                  Must be the pump or water supply then. U could trouble shoot the pump by taking off it's input source and sticking that in a bucket of water to see how she pumped. If that's it order a new pump, if not recheck connections for air leaks. This is what I'm using:
                  Flojet 03526 144A Triplex Diaphragm 3526 Series Automatic Water System Pump by Flojet http://www.amazon.com/dp/B002P33KVQ/..._p6hGtb1R26P6S
                  • SilentSeven
                    • Feb 2014
                    • 1868
                    • Bellevue WA
                    • 2004 Nautique 206
                    Well, did a bit of a field strip and observed some issues.
                    - scaling in the hot water feed, mostly at the temp mixing value. Think I blew most of that out.
                    - pinched with a zip tip cold water feed. Pulled the zip tie out but the hose still has some amount of kink in it
                    Generally, I get decent hot water feed but the cold water feed is spurty.
                    I can clearly hear the pump generate pressure...shut off...then turn on when I release the valve. But I seem to have some sort volume problem. Next is to pull the temp mixing valve and out inspect it closely.
                    Where does one look for leaks? I did tighten up / verify all the clamps were tight. Nothing discovered there.....
                    Bellevue WA
