GT-40 Impeller
  • Falcon1986
    • Apr 2011
    • 9
    • Montana
    • 97 ski nautique
    GT-40 Impeller
    Boat overheated so I followed previous threads to take impeller out and inspect. While taking apart, impeller dropped out before I could note the rotation. Can anyone describe which way fins go or provide a picture? Boat is 97 Ski Nautique. Thanks.
  • jasper
    • Feb 2005
    • 195
    Found this: http://www.correctcraftfan.com/forum...rPumpPlate.jpg Looks correct to me. Screw on housing towards engine. Water pulled from bottom to top of pump. Blades would probably flip if backwards, but it is good to avoid that stress.
    • hyparks
      • Feb 2011
      • 302
      • Brownhills, United Kingdom
      • 2001 Super Air 210
      Jaspers picture is right, I remember by rotating the impellar clockwise into the housing.
      Sent from my HTC One using Tapatalk 2
      Current
      2001 SAN 210, GT40
      Previous
      1994 Mastercraft Pro Star 190
      • 74hc
        • Mar 2013
        • 6
        • San Jose
        • 97 Nautique 196 - GT40 94 Nautique
        The cover on the impeller housing had a stain like mark caused by the impeller... made it real easy to know which way to install the impeller on my GT-40. However, I cannot see the impeller falling out of the housing unless it is significantly worn. It's a snug fit normally.
        It's a 97SN with a GT-40.
        • Falcon1986
          • Apr 2011
          • 9
          • Montana
          • 97 ski nautique
          Thanks for the picture and the comments. I ordered a new impeller today. The current one doesn't look worn but the fins have "set". I hope that's all that caused the overheating. I've checked all the hoses and couldn't find where air is coming into the system, so if it's not the impeller I'm scratching my head. Thanks again.
