Jabsco Ballast puppy in 03 super air
  • jamesra
    • Aug 2010
    • 3
    I recently purchased an 03 super air limited that does not have a belly ballast. I have an extra jabsco pump from my old boat and was wondering if there is a way to wire that in to the existing belly ballast switch to keep a clean factory appearance. Has anyone done this? Are the wires already run somewhere in the boat and is there a diagram? Thank you!
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    I have the wire diagram for my 04, probably the same as your 03. Are you installing reversible pumps? My 04 had simple bilge pumps in it for the ballast. Reversible pumps draw more amps and should not be run off the stock wires. You can install relays if you want to keep the stock switch functional. Make sure to use a relay with a diode in it or your gauges (all of them in the dash) will not work properly. I found this out the hard way. PM me and ill send you the wire diagram.
    • mnwakerider
      • May 2011
      • 271
      • Minneapolis, MN
      I created a similar thread. I will search for it and shoot the link. It has the wirin diagram like lakekackson said.
      Diode protected relays are what I mentioned in the PM. Those are key upfront.
      • mnwakerider
        • May 2011
        • 271
        • Minneapolis, MN
        Here's my thread
        http://www.planetnautique.com/vb3/sh...ad.php?t=22822
        • mnwakerider
          • May 2011
          • 271
          • Minneapolis, MN
          And this one
          http://www.planetnautique.com/vb3/sh...ad.php?t=20775
