Adding a 12 volt receptical
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    This is a dumb question but I can't seem to find the answer via Google so figured I'd ask here. I want to add an additional 12 volt receptacle to the cubby area under the combing pad in my boat. If I wire this directly to the battery (in-line fuse of course) will it draw any power when I don't have anything plugged into it? My thought is no but just trying to be sure I am not creating a potential battery drain when my boat is sitting during the week (no Perko switch yet). If it will drain the battery I will wire it to a switch. Thanks for your help!
    Shawn
    2012 Blue Metal Flake SAN 230
  • rcazwillis
    • Feb 2014
    • 117
    • Fort Worth, TX
    • 2002 SANTE
    It won't, but I would put it on the switch to avoid corrosion and keep the install clean
    Sent from my SM-G900V using Tapatalk
    • s_kelley2000
      • 1575
      • Mass
      Thank you! I have a direct line from the battery to the receptacle spot running behind the combing pad that would keep the install clean.
      Shawn
