2014 210 nss not working, any advice?
  • archcityblues
    • Aug 2013
    • 142
    • canada
    first time out this year and the nss wont engage?? tried shutting on and off, settings ect. the only change since last season was a surf pipe instal at the dealer. any suggestions? thanks
  • Shockthis
    • Mar 2013
    • 302
    • Christina Lake BC
    • 2021 centurion ri245
    Did you try the fuses?
    • 4th ski-doo
      • Apr 2013
      • 307
      • Wilmington
      • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
      I've become an expert at this.
      1. Does it turn on and off when you power up and down? They should drive in every time.
      2013 SANTE 210
      2011 Sport 200 V
      1994 Bimini Skier Pro 190
      • archcityblues
        • Aug 2013
        • 142
        • canada
        almost any question about a board i have a good shot at answering, but im a total idiot with mechanical/eletrical stuff. how do i locate the fuse for the nss?
        • archcityblues
          • Aug 2013
          • 142
          • canada
          no doesnt turn off and on at all. does not engage. button says its on, but nothing on either side.
          • newfoundskier
            • 30
            Is your speed control on?
            • nyryan2001
              • Mar 2013
              • 1993
              • Lake Anna
              Speed control on? Which side does the icon's arrow point to??
              post up a pic of your NSS on and the arrow pointing to either side pls.
              2019 G23 450
              2014 G23 550
              2013 G23 450
              2011 Malibu Wakesetter 247
              2007 Yamaha AR210
              • robertsmcfarland
                • Oct 2004
                • 544
                • Hyco
                • 2014 g23 550
                Jeff, this is for you, I know I have mention this before, I know we have very good knowledgeable members on this board, but have notice over the years even we get stumped!! but would be nice to have a separate column (ask the expert) answered by the Nautique employees ,or sponsored by one of our great dealers, or better yet open to all dealers. How many times have we had to stop boating because of a problem but could have kept going, only only if we had only known to jiggle this, bypass this, disconnect this etc. my two cents.... archcityblues hope you get and find the wright information to get you back surfing..
                2013 G23 super air
                2010 230 super air
                2009 220 super air
                2008 210 super air
                2005 210 super air
                2003 calabria pro air
                • archcityblues
                  • Aug 2013
                  • 142
                  • canada
                  Its frustrating, not sure what to do. Speed control is on, flipped arrow to both sides ect. I will keep you updated. In the meantime, if anyone has any suggestions, I will keep checking in here. Thanks
                  • Adam Greer
                    • Jun 2014
                    • 14
                    • Orlando, FL
                    Hey archcityblues,
                    Sorry you are having problems using your NSS. My guess is that at some point you had a NSS circuit fault and the channels have been disabled. To check this, go to settings (bottom right hard key), then system settings (top right hard key). Then "power distribution diagnostics" (5th hard key down i believe). Once you are in that menu you should see a list of all the electronics on the boat. Look for the port and starboard NSS actuators. If you see a yield sign with an "!" this means you had a fault and the channel was disabled. Press "reset circuits" and you should hear the actuators zero. If they icon returns it means you have a short somewhere in the NSS harness, if not you should be back in action.
                    • muskiedoo
                      • Jun 2013
                      • 30
                      • IN
                      • 2012 SANTE 230 w/ NSS
                      Originally posted by Adam Greer View Post
                      Hey archcityblues,
                      That's great info Adam! I see your from Orlando...And this is your first post. Are you employed by Nautique or just a LINK 2.0/NSS guru?
                      • iamcdn
                        • Mar 2013
                        • 337
                        • Penticton, Canada
                        • 2013 SANTE 210 with NSS
                        LinkedIn says product engineer at Correct Craft Welcome!
                        Hope that resolves your issues archcityblues
                        • Adam Greer
                          • Jun 2014
                          • 14
                          • Orlando, FL
                          I was just re-reading my post, settings is bottom left (sorry).
                          Iamcdn: thanks for doing the research ha. I cruise the forum from time to time to see what is going on out there.
                          archcityblues I am going to PM my direct line at the factory
                          • muskiedoo
                            • Jun 2013
                            • 30
                            • IN
                            Now how cool is that? Product engineer from Correct Craft here on site to answer our questions. Excellent customer service CC!
                            • lucky7t
                              • Mar 2011
                              • 1306
                              • Oklahoma
                              • 2015 SANTE
                              Adam ,
                              That's awesome you posted here. Thank you !
                              Current Correct Craft Boat
                              Correct Craft Boats Owned
