Prop Shaft Packing Gland Safety Wire
  • BrickBrock
    • Aug 2013
    • 66
    • Wisconsin
    I was trying to figure out if I had a dripless prop shaft seal in my 2005 SANTE (I think I have the standard drip seal). Do I need to check it when the shaft is turning or can I time the drips when the engine is off and the boat is just floating? I also noticed that someone prior to me cut the safety wire (see the attached photo). Does anyone know what length and thickness safety wire I should pick up locally to replace the cut safety wire? Can someone attach a photo of how the safety wire should look when properly installed? I assume that not having the safety wire is a safety issue, so I want to get it replaced as soon as possible. Thanks in advance.
  • laurie8888
    • Dec 2011
    • 162
    • dubai
    • nautique 206 and 200
    Just when boat is floating, std size wire I think 1 mm
    • BrickBrock
      • Aug 2013
      • 66
      • Wisconsin
      I found this in the manual. Laurie, thanks for your help.
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        • 2018 230 1981 Ski Nautique
        .032"
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2011 Sport 200V
        Sold - 2000 SAN
        • kend
          • Oct 2013
          • 193
          • DFW, Texas
          • current 2001 Air Nautique previous 1988 Sanger DX
          Potentially without a safety wire, running your boat in reverse could spin the nut off the shaft and cause you to sink. I found my boats previous owner had used a safety wire but saved $5 and not used any seal...yes you get more than a drip with no seal.
          Ken
          2001 DD Air GT40
