Was having a good day on the water yesterday until i went to shut my boat off after a set in the afternoon. Instantly everything shut off including my stereo. I found that the 60A breaker on the front of the motor had tripped. I reset it, started the boat back up and then perfect pass was going on and off and my volt gage was reading 13-14 bouncing back and fourth. Shut the boat off again and nothing. Had to reset the breaker again I am getting 14 volts with the boat running to I'm ignition switch. Anyone have any ideas what would cause the breaker to keep tripping? I also tried it with my stereo shut off and the problem did not go away. Any help would be awesome.
