Throttle Sticking - 2002 SANTE
  • wakehead
    • Dec 2009
    • 240
    Ok Guys, I have a problem with my throttle sticking. DOesnt go back to the quiet idle sticking. It looks liek the guy before me rigged some kind of a spring to always help pull the throttle back to its neutral position (On the engine). This one is definitely not a stock spring and its rigged. Sometimes I literally need to go to the back and pull the throttle back to its neutral state, very annoying !!! I noticed a "careburator" spring on nautique parts, but not sure if this is even a part for my boat or where it would even go for the throttle. I also have the PCM excalibur engine.
    Here is the link
    http://www.nautiqueparts.com/carbure...tlespring.aspx
    Can someone help me ??
    210 SANTE
  • azeus17
    • Feb 2008
    • 387
    • Grand Rapids, MI
    • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
    Sounds like you need a new throttle cable rather than a new band aid...
    http://www.nautiqueparts.com/control...rthrottle.aspx
    • wakehead
      • Dec 2009
      • 240
      Is it the cable itself that would cause it to stick? Seems like its more of an issue at the back, but hey, i am no mechanic.
      210 SANTE
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        You could rule out the cable by disconnecting it and operating the throttle by hand with engine off. If it returns freely, look hard at the cable.
        2005 SV-211
        • s_kelley2000
          • 1575
          • Fort Meadow Recevoir
          • Mass
          Does your boat have Perfect Pass or any other type of speed control? If so check to make sure that the servo motor isn't getting in the way of the throttle cable.
          Shawn
          2012 Blue Metal Flake SAN 230
          • wakehead
            • Dec 2009
            • 240
            I do have a perfect pass and I actually just ordered a new cap for the servo motor with the cable leading up to the throtlle body as the cap has bit the dust.
            This is my first stage to getting to fix the throttle sticking
            210 SANTE
