2014 230 Ballast Upgrade - Linc System Update
  • Gary_93_Sport
    • Jul 2005
    • 22
    I have a 2014 230 currently with pro ballast and would like to upgrade to larger ballast bags. Is the Linc system capable of changing the ballast amount beyond the pro ballast option? Obviously there is a setting to change from stock to pro ballast so the display reads correctly. Is it just a 2 setting selection or can the bag size/weight be set?
    If there is no capability in the Linc system, is the method to fill the bags beyond the pro ballast setup to just turn on the pumps manually once the system gets to the pro ballast full setting?
    Thanks!!
  • axeman
    • Apr 2012
    • 387
    • Dallas, TX
    • 2016 Super Air Nautique 230
    Gary,
    I've got this same setup. Ordered my 230 with the pro ballast option and swapped out the sacs from the factory with 550 lb sacs before it hit the water. The pumps will automatically adjust the fill/empty times based on your filling/emptying time spent.
    • Shockthis
      • Mar 2013
      • 302
      • Christina Lake BC
      • 2021 centurion ri245
      On your 2012 did it automatically adjust as well? I have a 2013 with additional ballast.
      Originally posted by axeman View Post
      Gary,
      • archcityblues
        • Aug 2013
        • 142
        • canada
        what axeman said. you might however be able to get a code from a dealer to increase what your ballast tank readings are in the linc.
        • Gary_93_Sport
          • Jul 2005
          • 22
          Axeman,
          Did the total weight change from 2100? What does the display show for max weight with the 550 sacs?
          • axeman
            • Apr 2012
            • 387
            • Dallas, TX
            Shockthis,
            Not sure of pre-2014s. I didn't have additional sacs plumbed in before. This was something that came up during my demo with the dealer.
            Gary,
            No, as far as I know there is no way to change that. Otherwise, I'm sure my dealer would have done it.
            • Gary_93_Sport
              • Jul 2005
              • 22
              Axeman,
              Did the %full settings and readings adjust for the added volume? So is 100% now based on the new volume vs the factory setup?
              What bags did you change to?
              Thanks!!
              • axeman
                • Apr 2012
                • 387
                • Dallas, TX
                Percent full readings adjusted appropriately and that's what I use to "gauge" the weight I'm running. I replaced the 300 lb sacs with 550 lb sacs. You can replace them with 750 lb sacs but then you can't use the rear compartment trays (they'll need to be removed).
                • Julius
                  • Jul 2016
                  • 20
                  • alabama
                  • 2014 230 SAN 2008 -SV211 2000 Pro Air Nautique
                  Ok.. on this post... are you guys experiencing the panels blowing out of the channels? If so, can you recommend how you reinforced them other than the wake makers bars which did not work for me...
                  • toomuchuv
                    • Mar 2013
                    • 190
                    • Canada
                    • 2014 SAN 230
                    You have to put pins in the side channels to keep the panels from riding up out of the bottom one.....
                    Sent from my SM-A520W using Tapatalk
                    "I'm on a boat........"
                    • Julius
                      • Jul 2016
                      • 20
                      • alabama
                      Yes... I had pins in AND oversized fat sacks that blew out the panels. Too much weight and heat caused the panels to bow and ride against the manifold. Its at the machine shop now in for repair. Will post pics of resolution.
                      • toomuchuv
                        • Mar 2013
                        • 190
                        • Canada
                        • 2014 SAN 230
                        Hmmm. I have 750s and haven't had an issue as long as pins are in.....
                        • kdonzi123
                          • Nov 2012
                          • 88
                          • Lake Hopatcong
                          • 2018 230
                          I had the dealer install the Wakemaker Engine Divider Panel Saver kit . I have 750 om a 2018 and have had no issues. If your not concerned about looks you can put a piece of plywood that comes up a 1/4 of the way . My buddy did that on his 2014.
