96 ss gt40 question
  • TeenagerPrincess
    • Apr 2014
    • 17
    • Branson
    96 ss gt40 question
    Ok boat was running great at about 40mph. In a turn I get a noise (sounds like I hit an air pocket and the prop was spinning) anyhow the boat reduced speed to 30 and it wasn't as smooth running. So i stop and start back. Put in gear has a vibration. Also Loss of power. I put throttle down take3x longer to get on plane. And max speed is 30 now. I pulled boat out and thought I would see a messed up prop. Everything looks normal. Maybe a slight ding-bend on one of the blades. Any help please?
  • TeenagerPrincess
    • Apr 2014
    • 17
    • Branson
    There was a bunch of stuff in the lake floating. I just assumed I hit something. That may not be the case.
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      Could you have hit something that got stuck on the tracking fins or rudder?
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
      • TeenagerPrincess
        • Apr 2014
        • 17
        • Branson
        I took it out and looked it over. Put it back in and still have the loss of get up and go. And when I put in gear had a decent vibration
        • TeenagerPrincess
          • Apr 2014
          • 17
          • Branson
          Should the prop spin freely or hard to turn by hand?
          • surroundsound64
            • Jul 2005
            • 2147
            • Longview, TX
            It should turn by hand, but not spin. If that makes sense. Does the shaft look bent?
            2018 SAN 230
            1981 Ski Nautique
            Sold - 2000 SAN
            • TeenagerPrincess
              • Apr 2014
              • 17
              • Branson
              Shaft looks fine. And prop spins if I make it.
              • surroundsound64
                • Jul 2005
                • 2147
                • Longview, TX
                Does it vibrate when in reverse too?
                2018 SAN 230
                1981 Ski Nautique
                Sold - 2000 SAN
                • NCH2oSki
                  • 1159
                  • Maryville, TN
                  • 2005 ski nautique 206 SE
                  Try a different prop, I bet one blade is out of whack, sometimes the damage is not obvious.
                  Prior Boats:
                  1999 Ski Nautique GT-40
                  www.skiersofknoxville.org
                  • TeenagerPrincess
                    • Apr 2014
                    • 17
                    • Branson
                    Reverse is a lot smoother.
                    • surroundsound64
                      • Jul 2005
                      • 2147
                      • Longview, TX
                      Yea, I would say you have a jacked up prop. If reverse is smooth then the shaft and the rest are probably fine.
                      2018 SAN 230
                      1981 Ski Nautique
                      Sold - 2000 SAN
