failure to increase revs
  • lilet
    • Apr 2011
    • 39
    • greece
    • Nautique 200 CB Nautique 196
    Hi all,
    new engine 343 the engine doesn't increase revs. Goes on gear and moving but nothing after this in the whole range of the throttle.
    Any ideas?
    Is the throttle cable connected?
    • lilet
      • Apr 2011
      • 39
      • greece
      Yes, I tried the throttle body on the engine
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        If perfect pass is not functioning properly, the throttle control will not work. The tension from the pp servo works in conjunction with the throttle to operate the throttle body
        2005 SV-211
        • lilet
          • Apr 2011
          • 39
          • greece
          Fixed, the butterfly from the throttle body was stack.
          Thank you
