Prop fix in San DIego
  • actiondcpd
    • Jan 2004
    • 147
    • Cardiff, CA
    I hit a floating log in shasta last week and it damaged my prop. Visually the prop looks fine but at speed the boat shakes a bit. Is there anywhere somebody can recommend a fix? I've got my spare on now so I'm not in a huge hurry. I'd like good work for a reasonable price.
  • richard
    • Feb 2005
    • 406
    • HK
    RE: Prop fix in San DIego
    very often u blended the pro shaft also after the prop hit the log,the shake if not from the prop,should be come from the little blended prop shaft, I hit stone one time last year and damaged the prop and shaft,I changed both. some shop can straigthen a blend shaft or repair prop,it may cost cheaper.
    • Gramps
      • 86
      • San Diego
      • 2003 Super Air Nautique Team Edition
      Call Eddie at San Diego Propellers in Spring Valley.......very good prices and a great turn around time.
      He will go way out of his way to take care of you.
      Tell him I sent you, he is a local rider and owns the shop.
      Gramps
      • clubmyke
        • Sep 2004
        • 414
        • so cal
        second that on san diego propellers in lemon grove... ed is a great guy..
        dont forget to tell him the repair is for a nautique otherwise the prop will "sing" at low rpms...
        • actiondcpd
          • Jan 2004
          • 147
          • Cardiff, CA
          I'm hoping to get the boat back in the water this weekend with my spare prop and check the vibrations. Thanks for the tips. Looks like I'll be making a trip down to Spring Valley! Thanks Gramps/clubmyke.
