1995 GT-40 Fuel Pump Replacement
  • Breck-Nautique
    • Dec 2003
    • 24
    • Colorado
    Hi All,
    Below is a link to the high pressure fuel pump replacement for the 1995 GT-40 EFI fuel system (without the FCC) at Nautique Parts. The output line connection is different than the OME connection and is stated as such on the Nautique Parts web page. I’m wondering if anyone has replaced their original pump with this pump and what they used to make the output connection to the fuel rail connection.
    http://www.nautiqueparts.com/fuelpum...tomid1996.aspx
    Thanks in advance for your input.
    1995 Ski Nautique, 351 EFI Ford GT 40, 310 HP, PCM 1.23: Trans. SKI & RIDE
  • Breck-Nautique
    • Dec 2003
    • 24
    • Colorado
    Ok, I’m was mistaken.
    Now that I look at my setup a little closer I see where I was confused. I was thinking the new pump had a taller line section between the pump to the connection nut. But after looking again this section of line is covered by the rubber mounting bushing. My bad. Sorry for the confusion.
