Ok I would like to thank this forum for getting me this far! Bought an 02' SANTE 210 with a cracked block. Had block replaced and rebuilt everything else. installed myself and cranked right up! Runs great at idle but around 2000-2100 rpms it starts to miss slightly, no power and makes a fluttering sound, if that makes sense. I found one loose plug wire and have new wires ordered. I don't feel like the engine would idle so well if the plug wires were the issue? I am leaning toward base timing not being right after a lot of research on this site. Any thoughts from better mechanics than me? Thanks!
Not exactly sure, but if I remember correctly, the base timing is not adjustable, but the cam retard is. It can only be set via the diacom software. I did have an issue with crossfiring on a brand new dist cap. Should be able to check each wire with an old school timing light looking for the same steady spark on all cylinders.2005 SV-211
Originally posted by ski4evr View PostNot exactly sure, but if I remember correctly, the base timing is not adjustable, but the cam retard is. It can only be set via the diacom software. I did have an issue with crossfiring on a brand new dist cap. Should be able to check each wire with an old school timing light looking for the same steady spark on all cylinders.
