Operating Temperature
  • Swiftowl
    • Jun 2005
    • 5
    • Newport Beach, CA
    • 1982 ski nautique 2001
    What temperature should my engine ( PCM 351) run at under normal operating conditions?
    • 2908
    RE: Operating Temperature
    somewhere between 140 and 180 is what I consider normal for boats, closer to 140 with no heater closer to 180 if you have a heater.
    • wake_fun
      • 1330
      • CA
      • 1995 Super Sport
      I had mine out yesterday and it ran at 140 the whole time. I just installed a heater so I guess I should go up to a 160 at least.......????
      Photo Album
      Ballast Install 1
      Ballast Install 2
      Amp Install
      PPass Install
      Alternator Install
      • Proud2BeCC
        • Mar 2004
        • 201
        • Warsaw, IN
        • 2002 Sport Nautique
        I've got a 1992 PCM with a heater and my engine runs at 160 deg. while getting a lot of water through the cooling system. It runs at 180 degrees while dependant on the water pump only while in idle. According to Vince at Discount Inboard Marine, this is normal.
        _____________________________________________
        Proud2BeCC
        2002 Sport Nautique
        (NDT) New Dimension Tower
        TowerBinimi Binimi Top
        Clarion CMD5
          • 2908
          Wakefun,
          Did you change the thermostat when you installed the heater?
          • wake_fun
            • 1330
            • CA
            • 1995 Super Sport
            Re: RE: Operating Temperature
            No I didn't..................
            Originally posted by Mikeski
            Wakefun,
            Photo Album
            Ballast Install 1
            Ballast Install 2
            Amp Install
            PPass Install
            Alternator Install
