Looking for a prop recommendation
  • Ryan H
    • May 2014
    • 12
    • SoCal
    • 2006 SAN 210
    2006 SANTE 210 used primarily for surfing.
    We nuked our prop a couple weeks ago and had it repaired. Re-installed and we are still getting some vibration. I thought it was beyond repair and should have just bought new from the get go. Oh well.
    We usually surf with 3-4 guys and have an additional 1,000lbs of ballast.
    Thanks and have a good 4th!
    Ryan
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Ryan, what prop did you have on there before? Were you happy with it?
    is a 38mph top speed ok for a signif improvement in low end tq? 20-23mph cruise ok?
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      http://www.wakemakers.com/nautique-w...oat-propellers
      maybe this can help, but i think they are missing your boat year....not sure if yours is like the 2005 or 2096
      • Ryan H
        • May 2014
        • 12
        • SoCal
        • 2006 SAN 210
        I had the factory prop and I'd be fine with 38mph top speed. We rarely open it up.
        • Ryan H
          • May 2014
          • 12
          • SoCal
          • 2006 SAN 210
          I got stuck there too. I tried to call and they were closed already. I'm almost certain the 06 210 is the same as 07.
          • scottb7
            • Aug 2011
            • 2198
            i thought people said the 2007 to 2013 were same. i don't know for sure...
            • Brichter14
              • Jun 2013
              • 531
              • Central Illinois
              2006 was first year of rh prop rotation.
              • scottb7
                • Aug 2011
                • 2198
                but what hull?
                • Ryan H
                  • May 2014
                  • 12
                  • SoCal
                  • 2006 SAN 210
                  Looks like the 645 is the stock prop based on the verbiage on this page:
                  http://www.nautiqueparts.com/propell...nautiques.aspx
                  • Brichter14
                    • Jun 2013
                    • 531
                    • Central Illinois
                    Scratch that. 2006 was LH rotating props
                    • nyryan2001
                      • Mar 2013
                      • 1993
                      • Lake Anna
                      Well i'd tell you to consider a 15x12" prop... It will be the equivalent of an engine upgrade in tq compared to what you had.
                      i don't know the LH prop designations... But a 15"dia 12" pitch .105 cup has been the standard for heavy ballast for about 2yrs now. Should put you right at 38-39mph top speed, but you will be 5-10 seconds faster launching from 0-23mph with full ballast. It's that big of a difference. Check to ensure you 'll have at least 1" of clearance with the larger prop from the hull.
                      2019 G23 450
                      2014 G23 550
                      2013 G23 450
                      2007 Yamaha AR210
