Blinking Bilge Light
  • Gatorsig
    • Jun 2014
    • 5
    • St. Augustine, FL / Lake Gaston, NC
    • Super Air 230
    I have a new 230 and the Bilge pump light on the control panel started blinking. I can't turn it off by pushing the button. If I turn the battery switch off and then on (after loading) I hear the bilge pump run for a few seconds but then the light starts blinking again.
    i can find nothing in the Owner's Manual about the blinking light. Can anyone help?
    also, after a day on the lake, I have 1.5-2" of water under the engine.
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Fyi, i had issues with my rear bilge pump also. A connection pin in a duetch plug or whatever they are called was the problem.
    the fuse and connection for the bilge pumps is not easy to get to, it's behind your keypad in the dash in the wiring... Weird place for that IMO. Better get your dealer on it and save yourself some time.
    mine was a quick swap to a new connector plug and issue solved.
    230s have 2 pumps correct?
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • laurie8888
      • Dec 2011
      • 162
      • dubai
      • nautique 206 and 200
      Nyryan what issue did you have.?
      Wrt the blinking light it's supposed to blink when bilge button pressed to on and ignition off. This indicates the bilge is primed However it is supposed to go off if you once again press the bilge button. I have same issue and just live with the blinking light
      • Gatorsig
        • Jun 2014
        • 5
        • Super Air 230
        Thanks. The 230 does have two bilge pumps - one easy to see, the other back behind the motor. I'm trying to reach my dealer today. This was only the 4th time out in the boat, so I'm pretty bummed that it has to go in for warranty work so soon......
