Do I need PCM plug wires for a GT40 or will Ford automotive ones work as well?
  • SilentSeven
    • Feb 2014
    • 1866
    • Bellevue WA
    • 2004 Nautique 206
    1997 GT40 if it helps.
    Bellevue WA
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    Auto is fine in this application
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • SilentSeven
      • Feb 2014
      • 1866
      • Bellevue WA
      • 2004 Nautique 206
      Thanks - Any chance you happen to know what part number or what year Ford and model will cross in?
      Bellevue WA
      • thedude
        • Apr 2007
        • 451
        • SW PA
        When I tried to use automotive wires on my Excal 330, they were too short to fit around the risers. Not sure if this is an issue with the GT40, might be worth taking your old set with you to match lengths to avoid two trips to the auto parts store. I'm guessing a good place to start would be to check the wires for a 95 Mustang GT with 5.0L. Or maybe a 93 Ford Lightning.
        • SilentSeven
          • Feb 2014
          • 1866
          • Bellevue WA
          • 2004 Nautique 206
          Well, have to say I punted on this and ordered PCM wires from Nautiqueparts. At $55, the likely savings was not significant enough to do all the futzing around to figure this out. For grins, I may take my old wires to my parts store and see if they can match them just so we can ID what make/year/model auto plug might fit.
          Bellevue WA
          • vortech347
            • Mar 2004
            • 95
            • Central Texas
            • 99 Sport Nautique - GT40 - FCT2 tower
            It's most likely a mid 80's Bronco with a 351. The 5.0 Mustang wires probably would not fit because the 302 is narrower than the 351.
            • kend
              • Oct 2013
              • 193
              • DFW, Texas
              • current 2001 Air Nautique previous 1988 Sanger DX
              For $55 you did the right thing. Have you ever seen cheap plug wires on a car at night put on an electric light show? I don't know that PCM wires have any special insulation, but I would hate to have a fuel leak and find out the hard way
              Ken
              2001 DD Air GT40
              • surroundsound64
                • Jul 2005
                • 2147
                • Longview, TX
                I've just used universal wire kits in a pinch. They are usually long enough.
                For $55 and if you aren't stuck right now, I would have ordered the OEM as well.
                2018 SAN 230
                1981 Ski Nautique
                Sold - 2000 SAN
                • east tx skier
                  • 1561
                  • Tyler, TX
                  You saved yourself some trouble for sure. It's not hard to find the 8mm wires off the shelf, but finding them in the right length with 90 degree boots on both ends is tricky. Best bet is to go to a race shop and have them custom cut. But at that point, I'm not sure you're saving much.
                  • SilentSeven
                    • Feb 2014
                    • 1866
                    • Bellevue WA
                    • 2004 Nautique 206
                    Actually, I'm pretty sure these are OEM from PCM. My current wires are likely original, are stamped PCM and are 8mm silicon wires. Decent ones for sure.
                    After doing some price checking on likely automotive substitutes, they were all in the same price ballpark or more. This particular part does not seem subject to typical 'marine part tariff' you can see on other items.
                    Bellevue WA
                    • east tx skier
                      • 1561
                      • Tyler, TX
                      I recall reading that the comparable Automotive Application for the GT-40 was the 1st Generation Ford Lightning 1993 or so.
