Intermittent tachometer
  • RickR90s
    • Jul 2014
    • 15
    • Detroit
    • '92
    Boat is a '91 Nautique with the PCM Ford 351 motor. The VDO tachometer has been working intermittently for awhile so I took the dash apart to investigate further. There are three wires going to the tach.
    Purple to the + terminal
    Gray to the SGL (Signal) terminal
    Black to the - terminal
    I pulled them all off and cleaned the male spades on the tach and made sure everything was clean and tight. I also fired up the motor to check the voltages and across the +/- I get about 13volts at idle. And the signal to ground connection shows about 6vdc. I have a nice Fluke meter with the bottom graph so I was expecting a pulsed signal but instead it showed a constant 6vdc.
    I also checked the connection block where the signal wires plugs in and cleaned those connections.
    In any case, I installed everything and now it doesn't work at all.
    Any insight would be appreciated.
    thanks,
    RickR90s
  • east tx skier
    • 1561
    • Tyler, TX
    If it has that little switch on the back, turn it through each position a few times and put it back on V8 or 8V or whatever it is. Worked with mine.
    • Orlandoguy82
      • Oct 2013
      • 4
      • Orlando
      • 1997 Sport Nautique Gt-40
      That truck of turning from 6cly to 8 cly worked for mine too
      • RickR90s
        • Jul 2014
        • 15
        • Detroit
        • '92
        thanks guys, I think I'll try that.
        • RickR90s
          • Jul 2014
          • 15
          • Detroit
          • '92
          Ok, this gauge has two switches/adjustments. One if for the 4,6,8 cylinder selection. The other adjustment appears to be a range adjuster. In either case, playing with both with the engine running did not solve the problem. Any other ideas would be appreciated.
          Like I said in my previous post, I am getting 12vdc across the two outside terminals. it's the middle SGL terminal that has me confused.
          • jhersey29
            • Nov 2013
            • 330
            • Colorado
            Use ohm meter on rpm sender and check the sender.
