Hydrogate Repair
  • KTompkins
    • Aug 2004
    • 34
    • Corpus Christi, TX
    • Current boat: 2009 210 SANTE Second boat: 1995 Sport Nautique First boat: 1982 2001
    Hydrogate Repair
    The Hydrogate lever has become detached from what ever controls it should be attached to. I will need to remove the panel that houses the throttle and the hydrogate lever mechanism. Any advise on that would be appreciated.
    '09 210 TE
    Old Boat: 1982 2001
    Old Boat: 1995 Sport Nautique
    New Boat: 2009 SANTE 210
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    Remove the screws around the hydrogate lever and then gently pry up on the ar/m rest cover. It is held in place with velcro like tabs. you may have to remove the speaker to give you space to reach up and attach cable nut if that is what is wrong.
    2008 210 SANTE
    • KTompkins
      • Aug 2004
      • 34
      Thanks, will try that. I'll let you know how that goes.
      Old Boat: 1982 2001
      • s_kelley2000
        • 1575
        • Fort Meadow Recevoir
        • Mass
        Are you sure the disconect is at the lever end and not on the other end by the gate? I am not sure if you can see it without removing the ballast tank but you may want to check there if you can see/feel it easily as it might save you some trouble.
        Shawn
        2012 Blue Metal Flake SAN 230
        • TxJole
          • Jun 2009
          • 898
          • Cedar Creek Lake TEXAS
          Lift out the SS cup holder insert and you can see what your working with. I'd look first.
          • KTompkins
            • Aug 2004
            • 34
            I heard something fall and then the lever just became loose. If the plate was wider I could just pull the lever out of the side panel.
            I'm hoping it was just a loosened nut that will fix it.
            Old Boat: 1982 2001
            • KTompkins
              • Aug 2004
              • 34
              Great idea. I'll do that first for sure. Thanks
              Old Boat: 1982 2001
              • xrichard
                • Aug 2008
                • 667
                • El Dorado Hills
                • 2023 G23
                On my 2008 if I need to get behind that panel, the steps are 1. remove throttle (phillips on push button and allen head underneath), 2. pop off the vinyl covered panel (held on with plastic "christmas tree" retainers...I use a thin pry bar wrapped in a towel to apply pressure next to each plug), 3. unscrew and remove plastic panel holding tank gauges (phillips).
                If yours is similar to '08 and uses the plastic christmas tree retainers, make sure you have some on hand for reinstall--it's likely you'll break one or two.
                Previous boats:
                2015 G23
                2008 SAN 210
                2002 XStar
                1995 Sport Nautique
