Hi Guys, New to the nautique world, I just purchased a G23. Love the boat. Part of the purchase was me installing the NSS system. Installation went great, but im having problems with updating the Linc system. I have a boutloader upgrade on the USB drive, and i also have the update for the NSS on a separate drive. I was told to just put the USB in, hold the home key and press the start button and it should just update. All it does is a black blank screen.How long should i be waiting?Does this take a minuit or too or hours? Im far away from the dealer i purchased it from, so draging it there from the lake im at is difficult- but if i have to its possible. Does anyone have any advise or experience on updating?
540, My dealer walked me thru a software flash over the phone.... I had the USB in hand, and you will still need a dealer code IIRC. software flash takes about 5 mins.
Call a dealer and ask them to walk you thru the process.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
It should show up on the screen with the file. You select it and it installs.2015 G23 Coastal Edition 450 NSS
2013 G23 Coastal Edition 450 NSS
There were some '13 models that wouldn't take the update. Some required replacement of the LINC system under warranty.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
true statement had to replace my linc screen because it would not except up date, mine went though 3/4 of up date but would then would go back to home screen and would not ever finish.2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
Well.... Thank you guys for the reply, Tried everything, dealer has been great. Nothing lets me even get to a screen that allows me to pick the file. They are ordering a new screen. Upon unplugging the Plug to install the NSS pins, the plug was soaked internally- corroded and the Power module pins were corroded. Strange for a new boat. Altho- i think it has nothing to do with the download issue. But the only wire that it could have wicked down from is the tower light, Still a sealed connector tho.
Hopefully it doesn't take to long to be able to try this surf system out!!!!
