HI,
I just purchased a new to me 2003 Sante. I LOVE this boat, but im having a couple of little problems. Boat has 397 hrs on it, but the former owner didn't winterize last year and cracked the block. Guy I bought it from had motor rebuilt and supposedly did pistons, rings, rods.....etc.... Boat runs perfect, most of the time. Sometimes when you accelerate hard, (doesn't matter if its loaded down, pulling a rider or just me in the boat and no weight) it will get to about 2500-2900 rpms then I lose throttle and it decelerates...At first I thught fuel filters, so I changed it and it was nasty. Still same problem....It just runs too good all the other times that I don't think its a fuel problem.
So yesterday while out I noticed something.....Sitting at idle Ive got about 20-25 lbs of oil pressure showing on the gauge. While riding hard it goes up to around 50-60 lbs. but everytime it cuts out yesterday I noticed the oil pressure dropping under heavy accerleration to around 10-15 lbs on the gauge....Could it be an oil pressure sensor going out instead of fuel problem???
Also yesterday I the stock clarion head unit lost power and so did the actuators buttons for the lt and rt rear hatchs....I checked the simple push fuse panel under dash but all looked good....I checked fuses behind stereo and they were good too....Are the anyother fuses I can check??? The manual doesn't show crap.......Thanks so much in advance for the help.....
Bryan
Bryan
