Guys
I purchased a NSS kit for a 2013 Nautique as well as your Lenco Dual Ram switch. Installing a NSS setup from a 2013 on my 2009 SANTE 230. I want to be able to cancel or retract the plates when going over say 15 mph similar to the Link 2.0 systems, (My boat has the regular gauges pre-linc).
Thinking I could setup something when either the Zero Off is engaged the NSS could be deployed via the 12 volts trigger wire for the Lenco switch ( orange in the diagram below ). Between 0 - 15 mpg it would enable and power 12 volts power the Lenco Switch enabling the trim tab switch. Over 15 mph it would drop the 12 volts power to the orange wire basically disabling the switch.
If power was dropped would the trim tabs retract or just be still engaged assuming so since power was dropped?
Open to ideas and feedback.
Zero Off Wiring Diagram
- When Zero Off is engaged it would have power 12 volts and it could be active it.
- When Zero Off is not engaged it would have 12 volts to enable it.
