paddlewheel voltage
  • 1955 classic
    • Apr 2013
    • 39
    • New Zealand
    paddlewheel voltage
    Boat is 3 hours away and i cannot check.
    on a 06 220 with paddlewheel and gateway, i need the paddlewheels supplied voltage. does the gateway supply 5volts (or something similar)as it is some-sort or a computer circuit which are normally rated to a max 5v,,, or is the paddlewheel run off a full 12volts,, thanks in advance
