Just started and motor cutting on and off, when off all gauges and ignition light turns off for one second then back on and repeats. Normally ignition light/fuse is always on, also ignition key switch was warm to the touch
Typical starting point would be to carefully check the kill switch and eliminate that as a possibility.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
If the igniution switch is warm to the touch, it is trying to tell you something.
Either too much current is going through it, because of excess load, or a short circuit somewhere, or the switch is going bad, and has high internal resistance, and normal current flow is being converted to heat. That means the voltage after the switch is low, and that could cause an ignition misfire.
Ok, ordered a new ignition switch but can believe this is the problem due to seeing the ignition switch light going on and off, not sure what it hooks up to but it's 20 years old, was thinking about switching with one from an the panel with less use...
Originally posted by DanielC View PostIf the igniution switch is warm to the touch, it is trying to tell you something.
Either too much current is going through it, because of excess load, or a short circuit somewhere, or the switch is going bad, and has high internal resistance, and normal current flow is being converted to heat. That means the voltage after the switch is low, and that could cause an ignition misfire.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
