I wanted to see if anyone has experienced this... I have a circuit fault on NSS Port... has the orange triangle next to it on the diagnostics page.... have tried to reset by hitting reset button, cycled battery off/on 3 times + start button, pressed circuit board buttons.... and nothing has worked... waiting to hear back from dealer but hoping it is simple so I wanted to put this out there. They think it might be electric actuator but checking on it... the only modification I did was add an LED light to the transom grills that light up when the switch surf button is touched but this takes so little power I can't imagine this is causing it but I guess it is possible.... anyone else experience anything like this? Thanks
Originally posted by ddipert View PostIt doesn't sound right that a LED would cause an issue. But I would undo what your have done to see if that clears up the issue. Are you sure you have good electrical connections on the work you did?
so the light come on to tell the surfer port or starboard???? sounds like a needed feature...2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
Originally posted by robertsmcfarland View Postso the light come on to tell the surfer port or starboard???? sounds like a needed feature...
