After reading some of the old threads about the tank removal and what a PITA it would be I settled on the piggy back idea. The threads I found said you had to jam it through the rear/chaise lounge. I really didn't want to work that hard. I started to get the boat apart a bit and take a real close look at the tanks. Looked like there was plenty of space to get them out. So gave it the ol' college try. I used the way I had to get the Centurion tanks out and they came out it a snap.......... way easier than I read so figured I would share. Remove the dividers as well as all the extra material to cover the tanks. You basically rotate the tank 45 degrees to the outside of the boat while you pull it up and Viola. My apologies if this has been shown, but I couldn't find it.
I went with Brostock 900LB sacs for the rear
Fly High Tube Sac for the locker
I personally think the 900's are way too much even with the rear tanks removed. The 750's would be perfect. I can't fill the 900 to the max to surf goofy as it curls just a bit at the top. However the bag fits the compartment perfectly. It's just overkill if you ask me. I was surfing at 10.4
With the sacs about half full and the piggy back in the locker the wakeboard wake was money. It had everything I needed for my intermediate abilities of 5 inverts, all the 180's, and a 3. I still need some extra up front so kept about 300 in pop bags to shift around.
