I pulled the boat out of the water about two weeks ago. It had no problems when I pulled it out. I towed it about two hours home and I put it back in the water today. Under hard acceleration there is a extremely noticeable vibration in the boat. It happens if I'm accelerating hard from idle or if I am Excellerating to a higher speed - like over 30.
It's severe enough that you would know not to push it. The boat does fine at lower speeds.
The only maintenance I did in the last two weeks was to replace the potentiometer (which I did not have calibrated yet) and the oil sensor. I have no idea how this ding got in the prop
I noticed this ding in the prop and I'm wondering if this is the cause of it or if it's possibly the unalibrated potentiometer.
Thanks
Thanks
