Boat is a 2003 Super air nautique. When I bought the boat it was missing a gauge on the right side of the display. Haven't been able to figure out what gauge is supposed to be in there. Any help would be greatly appreciated. I believe the boat is a limited edition. Thanks!
- Nov 2013
- 330
- Colorado
- 1971 Correct Craft Mustang 1988 Ski Nautique 1992 Ski Nautique 1999 Ski Nautique
Guessing the 4 you have are. Oil pressure, engine temp, fuel tank level, volts. two other good ones are depth or air and water temp. One gauge might be able to do all 3 but not sure.
Sent from my RM-877_nam_att_205 using Tapatalk
- Nov 2013
- 330
- Colorado
http://www.nautiqueparts.com/dashpanels.aspx is was factory with 4. Says to cut an extra hole for cruise control. Looks like they also cut ab extra hole for perfect pass. Best guess based on OEM parts.
Faria makes a nice depth finder with air/water temp, and there are several choices for transducers. I used a glue down through hull that sits in mineral oil. Its been much more reliable than the glue down puck that adheres directly to the hull.2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.org
No I didn't drill a hole through the hull. Its aNorcross Hawkeye D10D Depth Sounder and I got it from Amazon,,,go take a look there and read the reviews lots of great info on installations and also the instructions that come with are good. Always here to help ya out.
RonRON
Great information on the depth finders! Ordering one soon. Looking forward to getting one installed along with my other winter projects. The seacocks that let water in from the through hull are leaking and allowing water to fill the ballast bags. Ill be replacing them as well. Thanks for all the information!
