Voltage and alternator question
  • seth
    • Jun 2008
    • 549
    • Santa Barbara, CA
    • 01 SAN-sold
    So I just ran bigger wires to my dash and all my guages and PP work as they should. I expected that with the boat running that I would read a steady 13.x volts on the dash due to alternator charging. This is not the case. When I first started driving down the lake it was reading 13.5v but then for the rest of the day it was reading 12.2v. Is this normal? Is my alternator going out? Do I need a bigger alternator?
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    No, that is not normal.
    First thing's first. Use a multimeter and measure at the battery terminal when the dash gauge is reading 12.2v. Then you will know whether it is a gauge issue or not.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      You need to verify the voltage at the alternator and the helm with a diagnostic volt meter and not the rely on the helm gauge for diagnostics.
