I have a 2013 G23, ran it great the night before. The next day went to start it up in the afternoon to flush out the motor and the computer wouldn't come on. I checked to be sure I had power, it all checked out. I called the dealer to set up an appointment to take it in the next day. The next morning I tried to turn it on just to see what would happen and it turned on! Great, I come back later in the afternoon and it wouldn't turn on. Checked for power again, I have good power. I have had it at the dealer now for a week and they still haven't come up with the problem yet. Has anyone else had a similar issue?
Do you turn your battery switch on and off every use? I find that my 2014 will not turn the computer on every so often and was informed from my dealer that it's is from being too fast when turning on the battery switch and then entering the code not having enough time for the computer to boot prior to entering the code
We had that that happen on the first ride in the 200. We powered down completely, then powered up and started the engine. The Linc turned back on and haven't had a problem since. It was odd.'08 196LE (previous)
'07 196LE (previous)
2 - '06 196SE's (previous)
We had that happen earlier this month. It was our last weekend out on the boat this year and I was in a hurry to get it off the trailer. I haven't had it happen again, but when it did occur I think I was pretty quick to enter the code and back off the trailer after turning on the batteries.
Since I powered it off and on, I have had no problems.2013 G23 450
2004 Super Air 210
We got the boat back from the dealer. It ended up being a faulty key pad. I guess it was overheating and won't allow the linc system to boot up. Yes, we do turn off and on the battery switch and I have had the issue once or twice what was mentioned above, by turning the battery on the linc system wouldn't boot up. But by turn the batteries back off and on again it would work. Thank you for the suggestions.
