is this normal?
  • brttkrz
    • Nov 2012
    • 62
    • MN
    • 1995 Sport Nautique
    is this normal?
    Is this a normal amount of exhaust? full throttle from start to 35mph with 1700lbs of ballast in a 95 sport nautique with the GT-40.
  • jasper
    • Feb 2005
    • 195
    That looks like your cooling system is not cooling properly. Check impeller and/or leaks that suck air into the cooling system - all hose connections, water strainer, etc. My bet is impeller.
    • xlair
      • 694
      • Wisconsin
      Doesn't look all that abnormal. If it was cool outside it would be more noticeable as it is just steam from exhaust.
      2001 Pro Air Nautique
      • 2001SAN
        • Apr 2012
        • 203
        • Ireland
        • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
        http://www.planetnautique.com/vb3/sh...m-from-exhaust
        http://www.correctcraftfan.com/forum...m-from-exhaust
        • Laptom
          • Oct 2003
          • 876
          • Eindhoven, Netherlands
          A CC would steam a bit more than an other ski boat, but I think this is too much. Check your internal water pump. Not allot people will renew those pumps.
          • swc5150
            • 2240
            • Eau Claire, WI
            • MasterCraft Prostar
            What were the weather conditions? Doesn't look out of realm of normal to me, depending on conditions.
            '08 196LE (previous)
            '07 196LE (previous)
            2 - '06 196SE's (previous)
            • brttkrz
              • Nov 2012
              • 62
              • MN
              Water temp was 53 and air temp was 55. The engine was running at 158 not sure if the thermostate ever opened up. Usually it will run right at 160. I put in a new impeller the middle of last season. I have noticed that the gasket at the top of the exhaust manifolds is leaking just a touch of water. Could this cause that?
                It is normal. Gasoline is a hydrocarbon. Burning it creates water vapor, and carbon dioxide, and some other gasses. Burning gasoline, or any other fuel creates heat. Your engine uses lake water to absorb some of that heat. That makes hot water, and some of it evaporates in the heat from the engine exhaust.
                If the air temperature is close to the dew point, and it commonly is this time of year, all the extra water vapor from the engine makes fog, because when the exhaust is cooled to ambient temperature by the air and lake water, the exhaust is well below the dew point.
                You do not notice the exhaust fog in the summer, because the dew point of the exhaust is above the ambient temperature.
                • vision
                  • 518
                  • NC
                  • 2013 G23
                  Completely agree. Normal in colder temperatures.
                  • TRBenj
                    • 1681
                    • NWCT
                    Agreed, normal.
                    1990 Ski Nautique
                    NWCT
                    • xrichard
                      • Aug 2008
                      • 669
                      • El Dorado Hills
                      • 2023 G23
                      I had a 95 Sport Nautique w/GT40--in cooler temperatures, yours looks just like mine did.
                      Previous boats:
                      2015 G23
                      2008 SAN 210
                      2002 XStar
                      1995 Sport Nautique
