Flush kit on 2005 SANTE 330 Excalibur
  • tommer12
    • Apr 2004
    • 110
    • Fort Mill, SC
    • 2006 Ski Nautique 206 2005 Super Air 210 Team 1992 SNOB 1984 Ski Nautique
    Hey folks.. anyone have pictures or options for a flush kit on a 330 Excalibur? The options I have found are:
    http://www.marinetechgroup.com/index-2.html
    Basically a brass fitting that sits inline.
    Skidim has the Flush-pro
    http://www.skidim.com/prodinfo.asp?number=DP7
    Only reason to add it is to have it suck in a bucket of antifreeze or running on the trailer. If you added one to your 330 setup, could you post a picture of description on where you put it in?
    Vince at Skidim mentioned they pull the block drain plugs, drain the system, put the plugs back in, then suck antifreeze until it comes out the exhaust. Stop the engine, pull a plug and check for antifreeze at the block drain plug.
    Thoughts on these kind of devices for the 330?
    Thanks!
  • Skidave
    • May 2005
    • 697
    • York, PA
    I have a Flush-pro on my 330. Originally, it came with some PVC hose connector setup from Nautique. It leaked and was total garbage. I installed the Flush-pro and have not had any issues. I do not use it with antifreeze, so I can not support the operation of sucking fluids through the Flush-pro. I use it to connect my hose for spring maintenance and that is about it.
    FWIW, Vince is a stand-up guy and I have used SkiDim for years.
    Dave
