My boat starts fine on the first cold start, then I run it and after I turn it off and it sits for ten minutes or so, it has a hard time starting on the warm start. I have to give it gas to get it to start. It has good power and runs fine once I get it started.
I put a fuel pressure guage on the fuel system and it is losing pressure after I turn it off. It starts at 40+psi and after a few minutes after I turn it off it drops to less than 15psi.
So far, I have replaced the Fluid Temp sensor, Fuel pressure regulator, low and high fuel pump and overhauled the injectors. Fuel filter is clean. It is still losing pressure. I don't smell gas so I am assuming the tubes are not damaged. I may be wrong in this assumption. Any ideas? Is there a check valve anywhere else on this system? How else could I check to see where the fuel system is losing pressure?
Thank You,
Curt
Thank You,
Curt
