2014 G23 and I have an EZ Loader trailer. I am trying to put it in the yard and back it up using a Honda side by side with no electrical connection for the trailer lights / brakes. Of course with no electrical when you back up the surge brakes lock up. Should be no problem as you use the slide lockout thing to effectively turn them of. HOWEVER the trailer is different than the owners manual / directions show. The slot where the pin slides is behind the trailer "sheath." So the pin will not fit in there. Actually, I can't see how you can get anything back in there to keep the surge brakes from activating. Anybody have any suggestions? I'm stuck in the yard.
Thanks in advance.
Andrew Davis
(click pictures for bigger size)
Thanks in advance.
Andrew Davis
