replacing '95 strut
  • 95skiswany
    • Jul 2005
    • 1
    replacing '95 strut
    I hit a log and knock the strut out of alignment about an 1 1/2", I ordered a new strut and when i picked it up from the dealer I compared the plate holes of the bent strut with the new one, the holes were as much as 1/4" off, the tech at the dealer said to drill out the plate holes enough for the bolts to fit through the boat. After I got home and put the new strut under the boat I just couldn't bring myself to wallow out those holes without a second opinion, It just doesn't seem right to make the holes larger on such a important part.
    Should I return it or will the next one be the same?
    Where can you get this part other than thru the dealer?
    Can the old strut be repaired?
  • darrel409
    • Jul 2004
    • 566
    • San Dimas, So. Cal
    RE: replacing
    I have a 95 SN...had to replace strut last year and i got it from DIM. I forget the price but remember it was a little less than the CC. All holes lined up w/ same on new part.
