vinyl tear
  • tmb
    • Mar 2004
    • 616
    • Midwest
    • '22 GS 22 ‘12 200
    vinyl tear
    I just got a 1" tear in the vinyl along starboard side. Any suggestions on if this can be fixed or what to do? Thanks
    '18 SAN 210 Reef Blue/Admiral Blue Metal Flake
    '12 SAN 210 TE Black/Masters Blue
    '09 SAN 210 TE Black/Fury Red
    '08 Air 216 TE
    '02 Air 216
    '98 Sport Nautique
    '89 MC Prostar 190
  • ag4ever
    • 1180
    RE: vinyl tear
    I had some 1/8" tears fixed on my boat where the air chair had cut the vinyl, and I can't find the repairs. I would think it would be worth a try, but it might pull back open since it is so large. Is it in a high stress area?
    • OldFart
      • Jun 2004
      • 401
      • South of North & East of West
      RE: vinyl tear
      IF on the coaming pad or any piece near the edge, you can sometimes remove some staples (min 1'), pull the vinyl over the edge, & restaple.
      \"The voices aren\'t real...but they have some good ideas.\"
      • Socbum
        • Oct 2003
        • 268
        • Columbus, Ohio
        • 2002 210 Super Air Nautique Previous 1987 America
        RE: vinyl tear
        ag4ever, Did you do the repair? What kit do you reccommend? I tried the vinyl repair kit from west marine and it peeled off. My tear is about 1/2 inch.
        SocBum
        2002 SAN <== Current Boat
        1987 American Skier Advance <==First Boat
        • jeffsv211
          • Aug 2004
          • 161
          • Fort Wayne, IN
          • 2005 SV211 2008 220 --- current as of 1May \'09
          RE: vinyl tear
          On this subject, I had a sharp piece on the zipper of a swimsuit poke 5 holes in the seat as someone slid down into the driver's seat. Any suggestions? I know if I let it go it will turn into bigger problem? It's very noticeable and I assumed I'd just have to bite the bullet and replace the back of the driver's chair at the end of the year.
          2005 SV211
          2008 220 &lt;--- current as of 1May \'09
          • ag4ever
            • 1180
            RE: vinyl tear
            No, I had my dealer do the repair. I had like four little nicks and pin pricks repaired for the minimum charge of around $100. I know that if I tried to do the repair it would look like hammered dog poo. i would say that getting it repaired at an upholstery shop would be the way to go. Some shops will come to you, and some you will have to go to them. I guess it really depends on the cost of the new skin. If my holes were all in one skin, i would have just bought a new skin, but mine were on a seat back, both coming pads, and the observer's seat. The $100 minimum was much less than the cost of those skins.
            • DavidF
              • Sep 2004
              • 611
              • Austin, TX
              RE: vinyl tear
              Typically on a tear, the repair involves glueing a "patch" on the backside of the vinyl to hold the tear closed. Then the leftover scar is repaired conventionally.
              • 97sport
                • Mar 2005
                • 78
                • Youngstown, Ohio
                RE: vinyl tear
                Doe's any one know if you can buy factory skins from C.C.? I would like to keep it original if I can. Some of my seams are starting to seperate. Lucky no tears so far. Everyone's been carefull with the interior.
                • DavidF
                  • Sep 2004
                  • 611
                  • Austin, TX
                  RE: vinyl tear
                  Yes you can. Very expensive. I believe one of the CC distributors has all the patterns and gets a local shop to make the skins to order.
                  • aaron
                    • Apr 2026
                    • 114
                    • Malaysia
                    vinyl repair
                    search the internet for colorglo or colorglow ...apparently they are in the vinyl restoring business for cars, planes boats.
                    My local franchisee here did a good job on a half inch tear on my rear compartment vinyl
                    • JAG
                      • Jun 2005
                      • 98
                      RE: vinyl repair
                      I have used automotive vinyl repair kits with good suucees. The kit to puchase includes the electric flat iron for bonding the rapir material. You need to be carefull not to overheat the area being repaired or you'll end up with a bigger mess. If you can't find a kit at a local auto parts store you can purchase them from JC Whitney. The only problem is that the finish color may not match. I had this problem on my white seats and ended up painting the seat with white vinyl spray paint which to my surprise has lasted over 10 years now. Another alternative is to check with the local new car dealers. They usually have detailers they contract that specialize in cosmetic repairs including rips in vinyl.
