Had the boat on the lake today and the check engine light on the dash came on (not the v-drive light). My temp was 160 and oil pressure was 60 psi at idle. The engine also wouldnt go above 2500 RPM's it would cut in and out when it reached 2500 RPM's. Is this limp mode? I know that light is for the temp and oil pressure. How do i go about doing the checks to see if its the sensors and where are they? Thanks for eveyones help.
Joe
Joe
