Engine shut off in double up
  • fyerfytr
    • Jun 2005
    • 83
    • Des Moines, Iowa
    Yesterday I was pulling a rider thru a double up and as we crossed our wakes the boat shut down, is there a safety shut off or do I have a loose wire or somethig? It was fine after that I just punched in the code again
    and it was fine. The rider was a little confused tho!
    I have an '02 sante gt-40.
  • skinautique
    • 1749
    • Colorado
    RE: Engine shut off in double up
    Check your tether switch and make sure it wasn't bumped.
    • fyerfytr
      • Jun 2005
      • 83
      • Des Moines, Iowa
      Yep that was my first thought also, but it was ok. Maybe it has a short.
      It doesn't do it all the time just when it hits the rollers pretty hard so I usually just back down a bit and it doesn't do it. I wasn't sure if it had some other safety on it? But thanks for your input..
      Mark
      • skinautique
        • 1749
        • Colorado
        What engine is in it? Do you have any indicators showing up in the display of yoru guage?
        • fyerfytr
          • Jun 2005
          • 83
          • Des Moines, Iowa
          It's the GT-40, no there were no and are no indicator lights lit. It runs great till you hit a hard double up then it's like someone pulls the plug outta the wall, then i have to punch in the code and then good to go, it's weird.
          • Flux
            • 408
            • Palmdale, Ca.
            Sounds like a short to me. Maybe check the all on / all off/ bilge switch thingie too. Seems to me if you have to punch in the code all over again, the entire electrical system is turning off.
            • fyerfytr
              • Jun 2005
              • 83
              • Des Moines, Iowa
              yep I will have to look at the connections, thats all i can think of. thanks for the input...
              • Alan-S
                • Nov 2004
                • 161
                • Richmond, VA
                My money is on the "on / all off / bilge" switch. I have actually flipped it off with my toe and not realized it till like a min later while I am thinking "what the ****."
                • fyerfytr
                  • Jun 2005
                  • 83
                  • Des Moines, Iowa
                  Yes it was the Bilge switch! I replaced the switch and put on gold connectors and fixed the problem. Thanks for your help
