Fuel fill caps on '04 SN 196
  • jthooker
    • Jun 2005
    • 68
    • Mansfield, OH
    Both of the fuel fill caps on my '04 SN 196 are hard to unscrew all the way out even after the o-ring unseats.
    Also hard to screw back in.
    Obviously a thread binding problem.
    Don't want to lube with Never-Seize or anything messy like that.
    Anybody have a similar problem?
    Solutions?
    It's also a nuisance to get the chain to stay in the filler hole
    when I replace the cap without tipping the boat over on its side. :grin:
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    ditto
    Similar to my 05 196. I have never been a fan of the side fill tank. Great at the gas station, pain at the lake with a 5 gallon can. The chain that holds the cap is longer than what I had on my 02 and getting it all back in is that much more difficult.
    Make sure you don't have any sand in the threads, maybe clean them with a q-tip. Try a little WD-40 and see if that doesn't fix it. I would stay away from anti-seize, that stuff has a way of getting everywhere. Perhaps a touch of grease.
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • jthooker
      • Jun 2005
      • 68
      • Mansfield, OH
      j2nh, Thanks for the response.
      The threads are clean. No sand, etc.
      I guess I was putting any kind of grease in the “messy” category.
      I’ll try a little white grease and see if that helps.
      Couldn’t be much worse than the occasional fuel drips.
      I’m thinking about rigging small stainless extension springs on the
      chains to pull in the slack.
      • JayG80
        • Dec 2006
        • 206
        • Santa Fe, TX
        • 2007 Ski Nautique Sold 2002 Ski Nautique
        RE: Fuel fill caps on
        I have a petty annoyance with my 02 SN.
        The chain from the cap attaches to a piece that I will call a flange for lack of accurate term. When fueling with plastic cans, the nozzle works the flange loose. If I am not careful when removing the nozzle, I will drop the entire cap assembly into the lake.
        This is the case on both fuel caps. I have tightened the set screws but it still is an issue. My next step is to install longer set screws. Is there any type of epoxy I can use that is stable enough to cement the flange in place.
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          Rub a candle on the threads. This will lube them without the mess.
          Nautiqueless in San Diego
          • jthooker
            • Jun 2005
            • 68
            • Mansfield, OH
            Rick,
            The candle wax is a neat idea.
            I'll try it this weekend.
            Could have used your good advice when
            I posted this back in Aug. '05. Yellow_Flash_Colorz:
            Thanks for the tip!
