I can't get my perfect pass to turn off or engage properly. When I turn on the boat, the red light flashes and I am unable to turn off the system. Any idea what is wrong or how I can reset the perfect pass?
Tags: None
RE: 2000 Air Nautique Perfect Pass
To clarify, this is the perfect pass cruise, not wakeboard or slalom. It is the system that has the round control panel that has two buttons to engage, increase, decrease, and hit both simultatneously to disengage. Any help?
From PerfectPass:
System Reset – If you would like to reset the entire system to original factory
specifications, you can do so by pressing & holding the ON/OFF & MENU
Keys together as you power up the system. After about 5 seconds the display
will show { System Reset ^ = Y } Press the up key to continue with a reset.
It will then ask if you wish to run in just wakeboard modes {Wakeboard only ^=Y}
The next question will be whether you wish to reset all your baseline rpm values.
{Reset RPM @ ^ = Y } If you are happy with your baseline values, press the
down key and your settings will be maintained. On some systems, you will be
asked to select the engine in your boat.
