Any way to troubleshoot computer
  • NautiqueSS
    • Sep 2003
    • 28
    Hey I still haven't figured out what my problem is with the overheating. I did the last check by looking at the risers and their not bad at all so now I'm thinking it may be the computer but on a '97 with 800 hours? My other post is at the very bottom so if anyone knows a way to tell if the computer is bad please chime in. Thanks.
    1997 SuperSport GT-40
  • tryan
    • Nov 2003
    • 267
    • gatlinburg tn
    i may not be of any help , but if she running lean she'll get hot. can you check the fuel pressure? ( double check but 55psi seems like a standard #)
    take a block drain out and start the motor, water should spray out a pretty solid stream if you rev it up a tad. if not you engine water pump is bad.
    do you have a strainer? physicaly removed tranny and engine cooler? has she eaten an impeller at any time. ( skidim has a good punch list for overheating problems)
    a new thermostat does not mean it is good. check it on the stove.
    red right return
    • NautiqueSS
      • Sep 2003
      • 28
      Yeah I went down the whole list from skidims website and the water is flowing fine at every point, I'll check the fuel pressure though. I also heard something about an upgrade for the FCC, has anyone had problems with theirs? I think '97 was the first year for them or there abouts but it's got a new everything, filter, impeller, thermostat, temp and oil senders are on there way to being put in. Plenty of water is coming out the exhaust but it's very hot water.
      • tryan
        • Nov 2003
        • 267
        • gatlinburg tn
        if the new parts do not solve the problem, you might also look into the fuel rail changes on newer models. the solid metal rail had a rubber crossover pipe on later models to absorb the fuel pulse.
        it is typical for steam for to exit the exhaust.
        red right return
